Full 86-87 T.R. Engine Gasket Set
Red Regal T
Senior Member
Don't pay too much! Even with this lower gasket set price, you don't have to pay an extra $25 for the neoprene rear main seal kit and neoprene front cover seal. This is already included in this set along with the rope oil seals most no longer use.
These kits are top quality, NEW IN THE BOX, most gaskets in the kit are made in USA and others made in Canada and the kit contains the following gaskets.......
2 COMPOSITE TYPE HEAD GASKETS
1 CORK OIL PAN GASKET
2 CORK VALVE COVER GASKETS
1 NEOPRENE FRONT COVER SEAL
1 NEOPRENE REAR MAIN SEAL SET
1 O-RING FOR WATER OUTLET
6 VALVE STEM SEALS
7 FUEL INJECTOR O-RINGS
1 TIMING COVER GASKET
1 WATER PUMP GASKET
2 EXHAUST MANIFOLD GASKETS
1 OIL PICKUP SCREEN TO BLOCK GASKET
1 THROTTLE BODY TO PLENUM GASKET
1 UPPER PLENUM TO INTAKE MANIFOLD GASKET
1 VACUUM BLOCK GASKET
1 TURBO OIL RETURN GASKET
1 OIL PUMP GASKET
1 CAM SENSOR DRIVE O-RING
1 DRAIN PLUG NYLON WASHER
Don't forget, head gaskets, neoprene front and rear gaskets ARE included at this very low price.
SAVE A LOT !!!...................$115 includes shipping in USA :cool:
