Jun 16, 2005 #1 B b231v6 Senior Member Joined May 25, 2001 Messages 763 Can the fuse blocks be purchased new from GM or is that a junk yard purchase?
Jun 17, 2005 #2 M Maltman New Member Joined May 24, 2001 Messages 792 Just try your local dealer...they should be able to tell you if it is in the system or not. Otherwise, I think casper's has something to that effect...I think they have replicated pretty much everything by now
Jun 17, 2005 #3 T turbofish38 Le Pétomane Joined Dec 3, 2002 Messages 6,160 Junkyard or used. The only way you could get the fuse block was to buy the wiring harness under the dash and that harness is discontinued. The TR used a specific fuse block so that means you cant use the more commonlly available NA part.
