SignUp Now!The two points I was trying to make are:
1) If your time is worth anything and you don’t have a need to pull the engine and take it apart; the retrofit lifters are the easy way out;
and
2) Building an expensive RevKit type of retainer defeats the idea here. EXPENSIVE is the key word here.
The only reasonable way I can see to do this is to pull the engine and take it apart. A Buick oil pump is not going to do well ingesting cast iron chunks from drilling the block. There’s a lot of things that can be done to an engine while it’s still in the car; but at some point you’re wasting time.
I’ve got absolutely no problem with believing that this will work. I’m just trying to keep with the original plan of low cost and easy build. $250 ($350 for CompCams lifters - $100 for 3800 style) goes pretty quick at most machine shops today.
87buickracer: I’d love to hear more about the Cross Drill Patent.
Thanks again,
Joe
I got mine fired up for the first time tonight.... I am running near .590 lift on the intake...... 65 psi idling with the engine at 130 deg......motor sounds great..... but by 200 deg temp.... my oil pressure is in the ditch... down around 5 - 10 psi....![]()
I'm wondering if this is a lifter issue?
I'm running the 60* V6 lifters with no issues. My oil pressure is 30# hot at idle with 10w-40w oil with a booster plate. The lift on my valves is only .490 with 1.55 roller rockers though. When taking measurements I found running a cam with much over .520 valve lift the flats on the lifters were reaching their limit with the dogbones but I machined the tops of the lifter bores also to make them perpendicular to the bores which gave me a little less to play with. Do you know what the base circle diameter is of the cam your using?
It is a shielded foot lifter... but because I am running so much lift.... I am wondering if the body is traveling and uncovering the oil passage... and the motor is hemmoraging.
The stock 60 deg V6 lifter is a shielded foot lifter.... so I wouldn't think it would be hemmoraging......but wonder if the Johnson.... or the Comp 885 lifter body has the oil band at a different height.... or something else possibly different.... that might fix my oil pressure issue.
Anybody else running yet with a high lift cam... and the factoy 60 deg V6 lifters?
how's it sound?
Running presure is fine.... by 2000 RPM's she is close to 60 psi... even when hot and a 5 psi idle.....
Engine under 160 deg... pressure is 40 psi +.... but once it runs enough to kick the fans on a couple times... idling (fans cut on at 205 deg)..... idle pressure is a little below 10 psi.... like 5 or 6 psi..... tickle the throttle it shoots past 40 psi quick...
Is this a completely new build? If so; your pressure at idle should be above 10 PSI. If; it’s an older engine, extra low idle speed for that cool sound, or you’re intentionally running larger bearing clearance; 5 PSI is pretty common. The Buick oil pump is about as poorly engineered as possible and a lot can go wrong with it. Luckily; there’s almost no load on the engine at idle. It will most likely live for a long time like that. Make sure your idle speed is with in spec.
did you set the oil pump gear end clearance?
B
How about the cam bearings? Are they new or old?
