SignUp Now!ok folks,here it is.The part number for the pushrods is sealed power #rp 3253 and melling # mpr-309-B. length is 8.471".For high horse power applications I would use the comp cams 8.500" with adjustable roller rockers only.For non-adjustable stock and heavy duty stock rockers non-adjustable use 8.471"(rp3253 or mpr-309-B).At your local parts store you want the pushrods for a 1986 buick lesabre 3.8 v6 engine with vin code "B" as in Boy.This is the flat tappet cam motor pushrods,not the roller cam motor.Or if you have the money,just have comp cams make you a set of custom chrome moly pushrods 8.471".You can also vary the length a little depending on the thickness of your head gaskets and if your running adjustable roller rockers.So good luck to you guys and lets get some feed back on this set-up once we get the motors running.I know I can't wait to get mine fired up with my dual pump set-up.
Can the dog bones be used from the donor mor, i.e., 60 degree V6? Does the reatining plate have to be from the 3.8 FWD (I would guess yess to fit the valley).
Thanks guys
You can run adjustable push rods in an engine. They are inherently heavier and weaker than a non-adjustable rod of the same tube diameter. They would not be the first choice for a performance engine.
As for the holes in the lifter gallery; they aren’t completely necessary; but do provide oil return to the pan; and lubrication to the cam. As for any design that uses these holes to retain a bar-keeper (spider); you’d need to live with any disaster caused by fastener failure (this stuff is going to drop right on top of the crank); or figure a way that if it fails; nothing drops on the spinning crank and rods.
Thanks for all the work on this,
Joe
We need to devise a retention method for the spider that does not require drilling and tapping the block. So these can be retro-fitted without a teardown.
Anyone have any ideas?
Here’s the solution to the above problem:
Comp Cams CCA-853-12 sells at Summit for $346.
I don’t recall what the above rev-kit went for; but I think it was more than the retrofit lifters.
I think we’ve begun to miss the point. This was something that a lot of us have thought about over the years. A inexpensive way to run a roller setup on an engine not made to do so. In 20 plus years of messing with Buicks; this has always been the most economical solution I could come up with.
Honestly; I don’t have a better solution that the ones already presented here. If we start to figure the amount of time involved in converting the block to run the 3800 setup; and figure that the engine has to be removed so you can drill it without the cuttings dropping on the crank; the above roller lifters start to look like a bargain.
Don’t get me wrong. I’m still going to work in this direction; and my next try is with a Brand-X (Chevy) V-6 lifter retainer. But; there’s a bunch of kid stuff and bicycles in the way of the engine stand as I write this.
I deeply appreciate how much work all of you have put into this project; and don’t want to discourage anyone.
Sorry; rear derailer won’t shift and the kids are letting me know.
Thanks guys,
Joe
