I took some time yesterday to measure all the tubing in the 25.3 cage/chassis. I wanted to try and calculate and compare weight of the car before & after the upgrade/changes.
The old 10 point cage had 68' of tubing and weighed 155 #'s with the swing out side bars.
The 25.3 cage has 197' of tubing and weighs 197 #'s.
I also boxed the frame rails with 1/8" plate which added and additional 14 #'s.
Other weight additions are the fire system (25#'s) and the driveshaft enclosure (8.5#'s).
Now weight removed that I was able to weigh:
12 bolt vs new 9" housing complete = -17#
stock vs f/g trunk lid = -27#
stock vs f/g doors = -132#
stock vs f/g dash = -10#
swap mufflers = -3#
remove wood storage lid = -12#
remove coil spring mounts = -8#
remove trans X-member and flat strap driveshaft loop = -11#
Total of the weighed removed items is 220#'s.
Car originally weighed 3200 lbs w/driver and no ballast.
3200
-155
3045 net
+211
+33.5 fire sys & d/s encl
3289.5 after 25.3 cage
-220 weight removal
3069.5 net weight after 25.3
Now there were other items removed which I was not able to weigh, so I had to make some educated guesses.
- middle floor crossmember = ~3#
- rear seat floor crossmember & body mounts = ~6#
- rear steel floors, package tray and rear firewall = ~12#
- 6 aluminum body bushings eliminated out back = ~6#
- outer frame rail skins = ~10#
- old floor brace pads = ~1#
- steering column bracket = ~1#
- trunk lid latch bracket = -0#
- 4 gauge power cables (2) = ~6#
- #10AN return fuel line = ~2 #
- removed plastic inner fenders & metal bracing from fenders = -5#'s
This list totals approx 52 lbs.
So the potential new weight if nothing else is changed would be:
3069
- 52
3017#'s.
Now I still have a couple more small things that could take a little more weight out.
- swap remaining stock glass for lexan.
- build chromoly tube core support to replace stock (mine is lightened and weighs 21 #'S). Tube would likely be less than 5 #'s.
- swap huge 19 x 31 radiator for smaller unit.
I could even get rid of the hinges Glasstek f/g hood as it weighs around 45 lbs, but I had a lift off hood and refuse to go back. lol
I'd like to get the car under 3000 lbs, 2950 would be great, but doubt it'll happen.
swap mufflers = -3#
3200
-155
3045 net
+211
-220 weight removal
3069
- 52
3017#'s.
