blue_eyes4dss
- Jul 2, 2008
I am in the process of rebuilding my entire front end with Tubular upper and lower control arms from "Gbodyparts.com" . I have them installed and connected to the stock spindles. By looking at it, something does not seem right. The old stock upper control arms have a bit of drop from the ball joint to the shaft that connects up to the frame. The new tubular control arms are even with the top of the ball joint to the shaft. Does this matter?
The old upper control arms had a bump stop that came in contact with the frame when the car was lifted off the wheels. The new tubular control arms rub up against the frame near the rear of the control arms........does this seem normal? I figured the shock would prevent travel, but that does seem like a lot of load for the shock to control. Doesn't matter because the upper tubular control arm makes contact with the frame before the shock is fully extended.
Has anybody ever installed this setup with any problems/Success?
Any input would be greatly appriciated.
