1986 Buick GX1
GX1 #001 [The One and Only]
- Apr 24, 2015
That's not exactly true either. To have a 2004R rebuilt to stock specs, not a stage 1 build or whatever some builders name it is less than one thousand dollars.
Most builders lowest price build is better than a factory original build but does cost more than a basic rebuild because they usually do some mods that are above a standard rebuild.
3 grand will get you a full billet unit capable of north of 800 hp.
Stock spec rebuild is less than a grand, hence why a used unit isn't worth what he's asking.
If he gets 900 for his I have four units that I will be selling as fast as possible.
I was just thinking he could get a killer turbo 400, converter, crossmember, shifter and driveshaft all to go for the $3,000.
Good info, thank you.
