SignUp Now!SloGN said:i have a gt6152E and it's a killer turbo love it
The Don said:can I use 50lb injectors with this turbo or do I need to step it up bigger? What stall do you reccommend? can I keep my stock cam. I'm looking for mid to low 12's.
F-1 said:I'll save you some reading off of the other thread.. Hands down a PERFECT street/strip turbo.... It has performed well above my expectations... Check out my sig... :biggrin:
Precision Turbo talk to Don,
Patrick @ precision is awesome as well.
I went 11.4 on the 6152 turbo with the regular 3 inch inlet. No problems with 50# injectors and alky. Without alky, the injectors may be too small if you really push the turbo to more than 23lbs boost or so. I was using a 9" 3200 stall converter with an RJC boost controller. Without the boost controller, it was a little laggy and I think 3400 stall or so would be ideal.
You should have no problem taking a good running car to low 12s on this turbo. Stock cam is fine but you may need to switch to 28" tall tires as your mph increases in the 1/4.
With a tighter converter and higher flowing intercooler, I think I could get down to real low 11s on stock heads.
BTW my car weighs with a 1/4 tank of gas with weld draglites on it it weighed 3505. so my race weight is 3665
