Getting out!, Selling Everything. Lots of Engine parts
ARP head studs, Non-Stage block, Used Pending Sale
ARP Rod Bolts, Unused, SOLD
'148 86-87 ECM, No Chip, SOLD
Kenne Bell Regulator, with Fuel Rail $60
MSD 50lb injectors, and Joe Lebrant Chip for 93 Octane $175 Shipped
Stock 86/87 Upper and Lower intake, bead blasted, unported SOLD
Stock 86/87 Turbo, Some shaft play, no bent fins, complete minus inlet bell, $75
New TRW Single Roller timing chain for use without tensioner $25 shipped
Pass side 86/87 Header, Jet Hot coated, great shape $100 shipped
8445 Heads, back from the machine shop, 3 angle valve job, new seals and Comp 980 springs. Unported. SOLD
84/85 Turbo Block, Stock bore, honed, back from the machine shop, new freeze plugs and cam bearings. $100
Stock turbo crankshaft, STD/STD, journals are in great shape, SOLD
Stock 2 dot rods, with stock pistons, great shape, $50, pistons are reusable.
20 bolt timing cover, bought from intercooled88ss, SOLD
Turbo Riv Wiring harness, could use some repair, $20
Regal 3.8l frame pads, $15
Erson 214/214 flat tappet cam, with lifters, packaged individually so they can get put back in the exact same spot. SOLD
Buick Engine to Chevy Transmission adapter, Brand new. SOLD
Im gathering up the boxes and materials to get this stuff ready to ship, sorry for the delay, but I will guarentee your parts will go out this week.
TTT. Still have the injectors, Regulator. Turbo, Passenger side header. Lots of stuff left.
Heads still pending.
Here are the pics of the heads.
The following parts have been shipped out today:
Intake upper and lower, cam and lifters, Crankshaft,Timing Cover,Ecm, and Adapter plate. All Pm's Sent with tracking numbers.
Good useable stock turbo, $50 plus shipping....Rock bottom prices without the Yellow smiley face, and the door greeter.
NEW PRICES
Injectors and chip $150 shipped
86/87 Passenger Side exhaust manifold that is JET HOT coated $80 shipped
Factory 2 dot rods, with good stock pistons $40
8445 Cylinders heads, fresh from the Machine shop, with comp 980 springs, and 3 angle valve job $190 shipped
Stock turbo, very little shaft play, bolt on and go, or use it as a good core $50 plus shipping
Make reasonable offers on this stuff. I can ship this week.
New TRW Single Roller timing chain for use without tensioner $20
Pass side 86/87 Header, Jet Hot coated, great shape $80 shipped
8445 Heads, back from the machine shop, 3 angle valve job, new seals and Comp 980 springs. Unported. $175 SHIPPED, UPPER 48
84/85 Turbo Block, Stock bore, honed, back from the machine shop, new freeze plugs and cam bearings. $100 plus shipping.
Stock 2 dot rods, with stock pistons, great shape, $30
Turbo Riv Wiring harness, could use some repair, $30
NEW PRICES
Bump. OIL PAN IS FOR A TURBO RIVIERA, 20 bolt, apparently different than a Buick GN. Still for sale. $45 shipped
Still have jet hot coated manifold
85 Turbo Block
Pistons and rods
Stock injectors and fuel rail 85 yr
85 Turbo Riviera oil pan $45 shipped
