Global West 'Top of the Line' front upper A arms
GNICETRY
Cat&wife post starter
I have a set of top of the line, part#CNR-88-CB, upper front a arms from Global West. They are NEW in the box. These come with the cross shafts, del-a-lum bushings in the upper arm, ball joints and brass bushings in the upper arm (to negate downpipe heat). These also come with 4 del-a-lum lower control arm bushings for the front lower a arms. These are BRAND NEW, never installed, in the box. You need a taller (b-body spindle) for these to work. They are $663 on the website. I would like to get $550 for them. You can email me with any questions gnicetry@hvc.rr.com.
They can be seen here:
http://www.globalwest.net/1973-87 G...components.htm#Front Tubular Control Arm Kits
are these stock replacments or for the B-body upgrade?
****cancel that just read the entire post sorry.**********
I tried googleing the price but did not have any luck. A lot of people use the spindles and the arms on bigger brake kits. Even if you had to buy the spindles the price of the arms would more than make up for it.
