I'm having the exact same issue when I run my car on a hot (for Canada) day. Once I run it up a few times, I can't find the problem. But after a hard dash and some fooling around on the highway, I've had to coast into gas stations after a few nasty backfires (scary) and towed it home and it starts up the next morning. (note: this was last summer and there were posts on here about it)
I have replaced a lot of stuff, but I'm leaning towards the timing chain now. I'm wondering if the cam and crank sensors can get somewhat out of phase after too much slack. I've replaced the cam and crank sensor. I've replaced the coilpacks and the ignition module a few years ago and it just started doing this last summer.
Since last summer I've kept the boost under 15 and if I don't run it really hard, I haven't seen the issue since. I'm planning to change the timing chain and get on it again to find the faults.
Best of luck, I'll be watching your post to see what happens.
So was it the new crank sensor that eventually solved your problems? Have much have you driven the car since? I'm having similar issues and would like to know what you did to cure your problem.
