GNS Test car For Sale!
Status
Not open for further replies.
Going over to PT.com next.... I don't think this is too bad of a price considering this car has already been sorted out and it has all the best parts available for the G-Body cars on it already.... You couldn't build this exact same car for what I'm asking....
Maybe I missed it, but I didn't see you post an ad or a price for the car :confused:
edit: O I see, you updated the first post of this thread :oops:
Wow i just creamed my jeans..have loved that car for years..gotta buy lottery tickets....
Business is no longer for sale! My wife and I have decided to keep it...
The car IS for sale though!
This car has been a feature car in GM High Tech Performance, On cover of a new book, set up as a True Pro-Touring car which has been dialed in by Ridetech at the latest RTTH pro-touring event 9/13-14/13. Over $45k invested in this car alone! Asking $32k
1986 Buick T-Type Specs’
Engine: Fresh Balanced & Blueprinted by Richard Clark & Myself (2012)
  • I have the blueprint sheet that Richard Clark & I did showing all measurements of the whole engine!
  • J&E Pistons .20 over with J&E file fit rings done by myself
  • Carrillo “H” beam rods w/ ARP L19 rod bolts
  • Seal Power bearings (2012)
  • ARP Main studs – New (2012)
  • ARP Head bolts – New (2012)
  • Stock heads w/ stainless steel valves & new Viton seals – New valve job ( 2012 )
  • Alky Control Progressive Methanol injection – New Pump in 2012
  • H&R Poly motor mounts
  • 55lb Injectors – (Matched & Flowed)
  • TE-44 Turbo w/ Garrett exhaust Housing – Freshly rebuilt by "Bison" (2012)
  • Blue printed Oil Pump by Richard Clark – New in (2012)
  • Comp Cams 206-206 flat tappet cam – New in (2012)
  • Eastern Performance Front mount Inter-cooler
  • 3” Stainless Steel down pipe with RJC waste gate puck installed
  • F-body aluminum radiator
  • 160* T-stat
  • Intrepid Dual fans
  • Built 2004r trans, 500 boost valve, billet servo, alto clutches.
  • Protorque 3000 stall (Spragless) Non lock up converter w/ all fins Tig welded
  • GNS Cold air intake
  • LT1 MAF
  • Stock Ignition with custom fit MOROSO Ultra 40 wires
  • Extender programmable chip
  • Translator Plus programmable box
  • GNS Carbon Fiber Core support braces
  • Custom one off baffled oil pan by RJC Racing for Auto-X / Road racing
  • Power logger data saving software installed onto OEM computer
  • New Quick Ratio steering box (2012)
Exhaust system:
  • Dual ATR 3” stainless steel exhaust with Pit bull mufflers
Interior:
  • Pro-car Elite 1100 seats by Scat with custom Suede inserts
  • Suede head liner
  • Suede upper door panels
  • Stock rear seats custom upholstered to match the fronts
  • Suede rear deck lid
  • Whole interior dyed black
  • New black carpet
  • Custom made GNX style dash with white faced Phantom Auto-meter gauges and LED lights as turn signal markers. Also has the ALKY turn on and low level lights built into the face of the dash cluster.
  • Pioneer stereo with remote (New 2013 )
  • Rockford Fossgate Component speakers & Tweeters in front. (New 2013)
  • Pioneer 3-way speakers in rear deck lid. ( New 2013)
  • Scan master
Suspension:
  • Front- Ridetech's NEW “Tru-Turn Upper & lower A-arms (with Delrin bushings) with caser tuner slugs. (New 2013)
  • Front- DSE frame braces
  • Front- DSE Sway bar
  • Front- Ridetech Single Adjustable Coil Overs (New 2013)
  • DSE - Steering Shaft
  • Rear-Ridetech Single adjustable Coil Overs (New 2013)
  • Rear- DSE Upper adjustable control arms (with DSE’s swivel link ends)
  • Rear- DSE Lower adjustable control arms (with DSE’s swivel link ends)
  • Rear- DSE Sway bar (Chassis mounted & adjustable)
Wheels & Tires:
  • Made by CCW (Classic Custom Wheel) 3pc racing wheels – weigh 20lbs ea.
  • Centers were black brushed anodized along with the center caps
  • All locking black Gorilla lug nuts
  • Front: 18” x 9.5”- 4.75” back spacing
  • Rear : 18” x 10” - 4.75” back spacing
TIRES
  • Front: BFG KDW2 255/35-18 ( New Sept 2013 )
  • Rear: BFG KDW2 295/35-18 ( New Sept 2013 )
BAER Disc Brakes:
  • FRONT- BAER Track 4 featuring 13” rotors with 4-piston calipers, new OEM spindles, new bearings, stainless steel lines.
  • REAR- BAER SS4 system featuring 12” rotors with 4-piston calipers, Emergency brake set up, braided Stainless Steel lines, new e-brake cables
  • BAER proportioning valve
  • GNS Proportioning valve bracket
  • MCSS Vacuum brake system
Special Features:These items were done by us (GNS Performance) as this was their test bed for many products….
  • Tabbed smoked headlight covers
  • Custom trunk upholstery
  • Smoked marker light covers
  • Sequential LED Taillights (Not just bulbs either, these are actual boards with 187 LED’s)
  • Amber LED front Marker/Signals (Same style as above)
  • LED 3rd brake light
  • Custom made emblems inside & out on the car
  • Brake proportioning bracket
  • Translator plus bracket
  • Carbon Fiber Line-Loc bracket
  • Headlight screens for both the inner headlights (For cold air entering for the intake)
  • Tachometer/Alky bracket (Holds either a Tach or the Alky controller)
  • Carbon Fiber radiator top plate
Build Threads:
1) Was the DSE suspension build thread: http://www.turbobuick.com/forums/threads/complete-dse-suspension-build.329141/
2) Was the BAER brake install thread: http://www.turbobuick.com/forums/threads/baer-brake-install.343546/
3) Then we installed Ridetech's NEW "Tru-Turn" system & Coil Overs: http://www.turbobuick.com/forums/threads/ridetech-g-body-tru-turn-coil-over-install.397417/
Sorry they are staying on the car whether it sells or not...
I see no one's asked this question....so ill do it.
Scott, can I have the car?
Absolutely, as soon as i'm done counting out your money! ;) May even take a SVO in partial trade....lol
Sent from my SCH-R530U using TurboBuick Mobile mobile app
I think you misinterpreted my question. :)
I'm good with an even trade though.
No misinterpretation here, that was just my way of saying NO but I would be glad to have the cash.. ;)
Even trade for just my wheels & tires? LOL
Darn. It was worth a shot. If you said yes, I would have had a heart attack.
Here's a couple shots I always liked:
Hmmm, not sure why that second one shows up that way. Just click it to expand it.
Thanks for the pictures Dave!
You have been in my car and driven it more than anyone else, maybe you can explain your some of your experiences while in the car?
Yes Scot, I have driven it a lot!! For you guys or gals that are looking for something REALLY special in a Turbo Regal, this is the car you should be looking at!!!!
I have driven a lot of Turbo Regals over the years, and a great number of high performance muscle cars (remember, I'm an "old" guy) over the years which includes a good number of Corvettes (stock) through C5's.
This car of Scot's is literally like driving a slot car on the streets! I've never driven anything that "Sticks" like this one. Has a good ride! Perfect street manners!
Oh, and a ton of power!!
And of course it looks every bit as good as the pictures show. Several magazines have found it good enough to feature also!!
Of course the undercarriage is all brand new.
Oh, I forgot to mention the brakes!!!!!!!!!!!!!!!!!!! Even though they are vacuum brakes, Scot has them setup to perfection If you have false teeth, don't slam on the brakes in this car!! Fair warning, you will loose those falsies when you hit the brakes!!!!!
If I had the coin, I'd be on this car like "stink on you-know-what"!!
Scot seems to think that if he had an LS V8 in the car he could do a little better in the auto-cross sessions. Maybe, maybe not, I'm not so convinced since the car as is, pulls real hard, and spools fast! It's a flip of he coin as far as I'm concerned. I'd leave it as is!!!
You guys that build cars, take a look at the list of the build. You couldn't possibly build this car for as little as Scot is asking!! 30+K may sound like a lot, but it's a steal in this case!!!!!!
NO way in Hell you could duplicate this for less !!! I have over 45k in mine plus paint and it still has the stock rear end, driveshaft, brakes, front suspension, stock rear springs and shocks, no custom interior, no aftermarket wheels/tires...etc. The car is awesome...
Good luck Scot !!!!!!!
Bryan
I had a chance to ride in the car at Kodak, Tn's RTTH event earlier this year. It is one NICE TB! We made 3 hot laps on the autocross track under competition and it never missed a beat or broke a sweat. No oil leaks, no antifreeze leaks, nothing! Simply said, the car is FANTASTIC! While I knew it would accelerate like a bat out of hell (after all, it is a turbo Buick), I was not prepared for the outstanding cornering and braking performance. Scot is right on...this is a "slot car" for sure. While it wasn't the fastest car there, it certainly held its own. Look at the results...it finished ahead of a lot of nice, expensive cars! I can tell you that you cannot duplicate the car at twice the asking price! No way!!
Also, I want to thank Scot and Gina (and Doug and Kim) for their hospitality at RTTH. They made me feel welcome and a part of their rabid group.
Conrad
ps...I'm relieved that Scot is not selling GNS. I don't think that he realizes the extent of his contribution to corner-carving Regals (turbo'd or not). As far as I am concerned, he is our only supporting vendor concentrating on going around corners. Plus, you can buy everything you need (Detroit Speed, Ridetech, Baer, etc) from him and be assured it will all work together. I know that this is a tough business to make a living from so we ALL need to support Scot's business.
Status
