captndave737
- Feb 14, 2006
I'll post some pics when I get home nwxt week.
SignUp Now!I guess whatever you use to glue them to the fender would be a real chore to remove if you ever had to probably destroy them. Ever consider doing them in aluminum or light gauge steel?
I just figured with metal you could still use some sort of adhesive to hold them together that way you could probably put a little heat on them and pull them apart without tearing'em up.
No you do not ... it will slide in ....cut out and install..Do you need to remove the fender liners to install the wheelhouse patches?
Thanks,
Jim
