tpivette89
- Mar 27, 2002
So I've been doing alot of maintenance to my 1997 Buick Regal GS. The list includes:
- new Autolite 104 plugs gapped at 0.050"
- MSD Streetfire plug wires
- Jegs coil packs (cheaper than GM replacements)
- all fluids flushed and filled (castrol 10w40, Valvoline ATF, GM dexcool with RedLine water wetter)
- all filters replaced (air, fuel, oil, PCV, trans)
- new front and rear pads and rotors, and new brake fluid
- new Goodyear 225/60R16 tires at all 4 corners
- TB removed, cleaned, and new gasket installed
I'm planning on heading up to Cecil County Dragway for their test and tune session on May 7th. The weather here has been a bit on the hot side (temps in the 70s - low 80s), so conditions probably won't be ideal. However, I'm still going to try to get the best E/T and mph possible.
For the runs, I plan on setting up the car as such:
- rear tires inflated to 40 - 45 psi
- front tires aired down to 15 - 20 psi
- blower iced down in between runs
- car allowed to cool to 140* before racing
- adding a few gallons of 100 octane unleaded for insurance
Any predictions as what I should run? I'm hoping to break 14s, but realize it may not happen depending on air temps/conditions. I am an experienced drag racer (having many passes under my belt, but mainly with RWD cars), but I've only raced one FWD car at the dragstrip (2005 5speed Sunfire... went 15.8 at 88mph 100% bone stock).
A friend of mine is bringing his 1997 Olds Achieva to run me (2.4L/auto). It is stock with the exception of a CAI... he thinks it will be a good race with my Buick, but I'm guessing he hasn't done his homework on the potential of the L67 motor. Haha, I guess he"ll learn when we line up!
