usetaboost
SAY CAR RAMROD!!
- May 4, 2005
Cool man. Can't wait to see the finished product. You're getting more done than I am right now.
I was under the impression they had the filler hole in the wrong spot for the C/T setup?
Yes and no. You have to use the drivers side on the passenger and vice versa. I think Matt did this on his and has added a pipe to the back of the drivers side cover so he could put oil in it.
Long block is done. Just waiting on my PVC grommet to show up and the paint on my accessories to dry. Sorta wish I would have got my intake blasted to get rid of all that blue but ohh well. Too late now.
Looks good Jacob. Other than a stock build what have you done to it?
As far as the blaster Matt, it has to do with humidity. You need at least 1 dryer in line and I prefer 2 of them. Then get a shaker for the belly and clean the sand in a sive. If the gun clogs up put your hand on the nozzle and hit the trigger which will back flush it so you can keep blasting. If you want a media that will eat away at the crud super fast do a search for scatblast. I've used it before but don't use it on really soft metal. It will eat away just about anything if you don't pay attention to what you're doing.
There wont be any difference on the 83 housing Jacob. The exducer will be swollowed up by it. The larger housing and smaller wheel won't do what you're looking for.
My new H/O scoop from Lauren Engineering showed up. Coulda spent the money on a wideband but the car is getting painted this spring and I needed to get all my stuff for body work so theres a little logic there.
