Sam Colalillo
low 9's w/ a 109
- Jan 12, 2005
Comp Cams Billet Hydraulic Roller Cam 224 duration $250.00
Brand new never installed custom cam from Webber racing equipment
Part # 67-000-9 Serial # G 6291-06
Grind# WRE 10290019
………………….........Intake………Exhaust
Valve adjustment___HYD_____HYD
Gross valve lift_____.556____.556
Duration @
.006 tappet lift_____274_____274
Duration @ .050____224_____224
Lobe lift__________.359____.359
Lobe separation 112.0
Bell Tech 2” Drop spindles. $100.00
Used. I will include the rotors, which have just less than 1,000 miles on them if buyer wants them. They are still mounted to the spindles.
MSD -7562 Programmable boost controller $199.00
Brand new still in the box never installed. Purchased from Summit Racing equipment.
MSD Boost controller
Coil pack, ignition control module, and a set of MSD plug wires. $150.00
GM AC Delco module, the coil pack is from NAPA; both have just less than 1,000 miles on them.
The plug wires are the 8.5mm MSD super conductor wires (red). All looks brand new.
Grind# WRE 10290019
Duration @
