SignUp Now!I will pass. Please let snappy6 have them.I Have had then setting in the shop for 3 years and I got them used
223-4204 and that is shippedCan you provide the ARP part number. Is $80 the shipped price?
At this time want to keep togeterInterested in the RJC Water Pump & Power Steering pulleys if you'd separate.
Payment sent223-4204 and that is shipped
DoneWill David Abrams, please PM me
Like to sell as a set, for nowInterested in the RJC Water Pump & Power Steering pulleys if you'd separate.
New pics are upPics of power logger and lc-1 please
I'm have a moving sale all my GV stuff I was going to use, now has to go. I have not been on the board for some time, so my prices may be a little wacky. But I sure someone will point it out to me and the world.![]()
All items are plus shipping. I prefer to use PayPal. Items will be shipped from 65401 and I will try to ship USPS Flat Rate. Here is a link to pictures on Photo bucket.
Can you please fill me in on the front cover and oil pump (ie; impeller clearances to pump cavity and booster plate, who cleaned up the front cover oil oil pump passages,has it been run, re-pop or OEM) Thanks Wayne
Part Price
Console gauge pod $25.00
GN / T-Type 200-4R Shifter Detent Plate New $25.00
Driveshaft Loop $30.00
Billet GN Thermostat Housing New $30.00
RJC power plate for stock $40.00 Pending
Polished S.S. Throttle body Arm $45.00
SOLDRJC Boost control valve, like new$45.00
SOLDS/S Turbo feed and return line$50.00
GN / T-Type Ultimate J-rod & Aluminum Adjuster New $60.00
SOLDAluminum valves covers w/bolts$60.00
ARP head studs New$80.00SOLD
Ported Upper Plenum $80.00
Stainless Steel Upper Radiator Pipe w/Red silicone hose $100.00
Belltech 2" Drop Spindles $125.00
PTE Turbo Saver $140.00
Scanmaster 2.1SOLD$200.00
Power logger $200.00 w/ECM $225
New Innovate LC-1 Lambda Cable w/ O2 Sensor and Moates O-Meter $200.00
72# Siemens Deka injectors (8) $250.00
Fluid damper, with fire ring $250.00
Mod Front Cover/ with oil pump with booster plate $275.00
Stock lower intake, Port matched to GN-1 heads $275.00
RJC Billet Aluminum Pulleys, Crank, Water Pump, Power Steering $280.00
Morel Roller Lifters Never been installed, NEW in box $280.00 Pending
G-body Adjustable Edelbrock Upper Control Arms and Edelbrock Tubular Non-adjustable Lower Control Arms and Edelbrock Anti Hop Bars $300.00
MAF Translator Gen II w/ Plug-And-Play Adapter $325.00
PTC 3200 convertor with 500 miles $325.00
Razor's Progressive alky kit, NEW $475.00
Comp Cams 269HR Roller cam, 269/264 duration, just polished by Comp, COMP Cams High Energy Hydraulic Roller Lifters, push rods, valves springs retainer and keeper $500.00
ATR SS headers (missing 1 V band clamp). $700.00
GN-1 Aluminum Heads, ported & polished New beehive springs $1,400.00
Fresh 109 short block, 0 miles, unassembled, line hone, bore hone with deck plate, main girdle, rods and mains standard with .002 clearance and .004 end play. Bored .30 over with a piston clearance of .0065. JE Pistons and rods are assembled with Sealed Power Hellfire ring set with ring gaps of .032 top, .030 second. Balanced. Have Clevite 77 rod bearing, double roller timing chain, stock front cover w/ pump. Local pickup preferred. 100 miles west of St Louis, MO on I-44. Lets hear some offers
What kind of balancer is That and how much?? Is PL new with everything there to be usable???
Tony
Fluid damper, with fire ring $250Is the dampener that's pictured for sale?
