oldwirehead
Army NCO on inactive duty
- Oct 8, 2008
TTT
SignUp Now!I'm interested in the front cover. How many miles on it and who modded the the passages.What kind of oil pressure and what relief spring are you using?I'm have a moving sale all my GV stuff I was going to use, now has to go. I have not been on the board for some time, so my prices may be a little wacky. But I sure someone will point it out to me and the world.![]()
All items are plus shipping. I prefer to use PayPal. Items will be shipped from 65401 and I will try to ship USPS Flat Rate. Here is a link to pictures on Photo bucket. PayPal is oldwirehead@gmail.com
* new stuff
Part Price
Console gauge pod $25.00
GN / T-Type 200-4R Shifter Detent Plate New $25.00
Driveshaft Loop$30.00 SOLD
SOLDBillet GN Thermostat Housing New$30.00
RJC power plate for stock $40.00
* GN new Vacuum lines for all engine bay all correct size $40.00
Polished S.S. Throttle body Arm $45.00
SOLDRJC Boost control valve, like new$45.00
SOLDS/S Turbo feed and return line$50.00
Aluminum rear end cover w/gasket $50.00
* Fuel rail with has 8n fitting for return line $50.00
GN / T-Type Shifter Ultimate J-rod & Aluminum Adjuster New $60.00
SOLDAluminum valves covers w/bolts$60.00
ARP head studs New$80.00SOLD
Stock Ported Upper Plenum $80.00
SOLD* Precision plenum and RJC power plate $140.00
* Aluminum deep trans pan $100.00
* Auto meter 3905 tach w/shift light, just came back from Auto-meter $100
SOLDStainless Steel Upper Radiator Pipe w/Red silicone hose$100.00
Belltech 2" Drop Spindles $125.00
PTE Turbo Saver$140.00
Scanmaster 2.1SOLD$200.00
Power loggerSOLD$200.00 w/ECM $225
New Innovate LC-1 Lambda Cable w/ O2 Sensor and Moates O-Meter $200.00
72# Siemens Deka injectors (8) $250.00
Fluid damper, with fire ring $250.00
Mod Front Cover/ with oil pump with booster plate $275.00
SOLDStock lower intake, Port matched to GN-1 heads$275.00
PendingRJC Billet Aluminum Pulleys, Crank, Water Pump, Power Steering$280.00
Morel Roller Lifters Never been installed, NEW in box $280.00 Pending
SOLDG-body Adjustable Edelbrock Upper Control Arms and Edelbrock Tubular Non-adjustable Lower Control Arms and Edelbrock Anti Hop Bars$300.00
MAF Translator Gen II w/ Plug-And-Play Adapter $325.00
PTC 3200 convertor with 500 miles $325.00
Razor's Progressive alky kit, NEW $475.00
Comp Cams 269HR Roller cam, 269/264 duration, just polished by Comp, COMP Cams High Energy Hydraulic Roller Lifters, push rods, valves springs retainer and keeper $500.00
ATR SS headers (missing 1 V band clamp). $700.00
SOLDGN-1 Aluminum Heads, ported & polished New beehive springs$1,400.00
Fresh 109 short block, 0 miles, unassembled, line hone, bore hone with deck plate, main girdle, rods and mains standard with .002 clearance and .004 end play. Bored .30 over with a piston clearance of .0065. JE Pistons and rods are assembled with Sealed Power Hellfire ring set with ring gaps of .032 top, .030 second. Balanced. Have Clevite 77 rod bearing, double roller timing chain, stock front cover w/ pump. Local pickup preferred. 100 miles west of St Louis, MO on I-44. $2500. OBO
ThanksPaypal for another 21 sent to cover shipping and fees.
Please let me know when it ships.
Do you have any pics of the lower spindles, and if the roller rocker arms are still up for grabs I would like to take a look at them as well.PM Sent on Lowering Spindles
Trans pan is SOLD, rydersv6: do you want the rear cover and gasket?
Spindles still around?
95346104759131505349 80Do you have a tracking # for me ?
