Gtq 71
fastdon3
TGM PERFORMANCE
How Fast Can You Run And How Much Boost Pressure With This Turbo On A Stock 109
I did a search..71GTQ.
I see it likes a lot of boost 28-30+. Alot of threads saying the 70gtq is more fitting to run under 30 psi and still go low tens high nines. The 71 can run the same times just takes more psi.
Jason
The 71 uses a billet wheel which is lighter than the 70, and i wouldn't be taking a stock 109 block over 30 psi too much. You would be better off with the 70 as most suggest
You did alot of posting about this turbo in the threads i read. the 71 has a billlet wheel, what is the 70gtq wheel made of?
Most other turbos use a cast aluminum wheel, that is cast in a mold.
see sig
running 24/23psi (two stages controlled with MSBC-1)
without ported heads id say you dont need more than a 63mm to max out the heads which will just barely get you into the 10s on a good day
10.30 with a gtq 71. at 24 psi. that is one hell of a turbo. im thinking of getting on dbl bb!
whatcha been up to fast don?
