87gn-newbee
- May 25, 2001
Just finished the install and have a question on pre load. The way I'm reading the directions is no pre load unless you have traction issue and adjust at the track? Is no pre load when the rod ens are threaded in the hex spacer all the way? So basically no threads on either side of hex spacer are showing, correct?
