turbodave231
Moderator
- May 24, 2001
I've never owned a set of HS rockers......I have several sets of T&D's and tons of spare parts and use them on nearly every serious engine build. T&D's certainly aren't perfect either. I still end up shimming the rockers to center the roller on the valve tips. I've never had the binding issues described above.
I have a few questions about the bearing system and oiling. True!! the T&D's use the two rows of smaller needle bearings, The space between the rows is for oil to flow from the pushrod adjuster into the rocker body. The rockers have a hole drilled into this area allows oil to exit the rocker body and oil the roller tip and valve tip. If HS uses a solid single row of needles, how do the needles get lubrication? Splash? Drilled passage?
Last year I lost the needle bearings on one intake rocker arm. The needles just fell out and the bearing race was all ground up. Luckily I caught the failure before any debris hit the oil pan. I sent the intake rockers back to T&D and they told me that the cause was valve float. This makes sense, because I was seriously undersprung when I first put my S2 engine together. I bought 6 new intakes and Life is Good again!
