Its probably been asked,but I will ask again. What is the best headgasket on the market today for running 25+psi? I just blew 2 on my car they were the stock graphite gaskets. I was pushing the boost to about 25 when they let loose.
I see SCE makes copper gaskets with bead sealing around the water passages. Is anyone out there running these Sce's without problems with water leakage?? Im looking to build a 10-second car this winter.
I know the stock graphite gasket can take alot but was just looking for opinions on the others available. I do plan on installing ported heads, intake, and a roller cam this winter. I also am going to use head studs this time instead of head bolts. Maybe after I put the heads, intake on I could run less boost and make good power???
Any input is appreciated!
