- Jan 21, 2007
Are there any pros of irons over aluminums???
Price...and spend the savings on additional parts you may need or want. Especially if irons will work for your performance goals and it sounds like it will.
SignUp Now!Are there any pros of irons over aluminums???
I have asked this question before and the answer that i got was $$$$$ more for the aluminum heads.Are there any pros of irons over aluminums???
x3,,,,they both build awesome heads,there is no best.
I understand but when its forced in its a different world,very few guys will ever max a good set of iron heads they are better than you think and stay on the motor with the correct tune.In the naturally aspirated world I used to live in cylinder heads and cam were everything
it depends on the combo but you cant just change one part of the combo and expect massive gains there are potential gains but other areas need to be addressed to make the head shine.there are slow al headed cars out there as wellMy take on it is the Aluminum heads make the same power on less boost.
building a driver not a track car curious whats everyones opinion which head is better out of the box ta street intimidators or champions ? 20 over stroker not sure on the turbo yet and i would like to make 600-650 to the rears
I can assure you of one thing about the TA heads, you have them built/ported/springs to your specific requirements and budget, and on the way to you in 3-4 weeks, and you can reach me by phone from 8 AM to 8 PM most days!![]()
it depends on the combo but you cant just change one part of the combo and expect massive gains there are potential gains but other areas need to be addressed to make the head shine.there are slow al headed cars out there as well![]()
I would agree with this 100%
My small block Mopar makes big power on all motor. Cam, heads, Quench, Compression, intake, carb, exhaust, weight, gearing, converter etc were all taken in to consideration. Scott Brown designed the cam and Ryan Johnson did the heads. I made an extra 125HP at the tire by upgrading heads and cam. The car ran 11.10's at 119 with 1.5 60 prior to that change at 3440# race weight, would have went 10's with a better converter. Now 10.50's at 131 mph with the same 60. Only cost roughly $6500What's and extra few hundred bucks for TA heads
Now what I see on this side of the fence is a little different and I'm still learning, my comments are from my observation not experience. Combo's don't seem quite as critical to go fast. Tune it and throw boost at it. I see cam's from 206 to 218 in similar builds with similar ET's and MPH. How critical is it to get everything matched perfect when you have a turbo? Dunno? I'm seeing combos all over the place. Most cars weigh about the same (ish) gears are mostly the same at 3:42's etc. Fairly even playing field. I guess in my case I can utilize the TA heads with my build. Would I throw them on a stocker? No
Is the price difference a deal beaker (if you have the supporting parts) to go aluminum over irons? IMO no way.
If you can support the extra flow and you get a few benefits with the TA heads it's a no brainer to me. Can you get it done with irons? Absolutely but the price difference between the two just isn't far enough apart to worry about it.
Let me put it this way in your case the 45a cannot flow enough air to max out a ported iron head.combo is very important in these cars.I guess in my case I can utilize the TA heads with my build
That is my point most will never use a head like that and they are quite a bit more money with real port work and all the goodies.If you can support the extra flow and you get a few benefits with the TA heads it's a no brainer to me
650 rear wheel does not just automatically happen especially on a daily driver. In my opinion if your going to reach your goal at a streetable boost level you should do all you can to help the air get thru the engine.building a driver not a track car curious whats everyones opinion which head is better out of the box ta street intimidators or champions ? 20 over stroker not sure on the turbo yet and i would like to make 600-650 to the rears
