SignUp Now!Now that I have the block all stripped down, ready to go in for a decking....
Would it be worth the effort for 1/2" head bolts?
If you used alky each time it would be another thing that all failures had in common. When I blew gaskets with alky the cooling system always got pressurized and blew coolant into the overflow tank. No coolant in oil. When I blew gaskets without alky coolant always whent into the oil. Did your coolant go into the oil?The only common part left is the block.
DETONATION, whether your electronics sees it or not.
I'm still convinced the stock knock sensor and associated filter circuits was/is one of the best and most reliable designs out there. Assuming the sensor is properly installed (which in most cases, it isn't).
I will be logging fuel/alky this next round for sure, double pumper,new injectors etc. The car didn't smoke and the pcv had a check valve and a catch can installed. Thanks for the discussion guys, keep it coming!
The knock sensor is 2 seasons old, OEM torqued to 14ftlbs. I will look into honing and a new set of file fit rings if needed.
If its any consolation your combo is very similar to mine. Im running a classic FAST unit though.
Im convinced that the double pumper (old ATR) setup is not helping me here. I will be going with a Reds set up and using the Nitrous feature in the FAST to activate the second pump off of the MAP sensor.
Once I tune it on a dyno I will set the alky to help out.
I blew this thing again with 15 psi and the #5 setting on the alky. It should not have blown the head gasket but it did.
The combo is stock block, forged internals,steel heads ported and polished, intake ported and polished, liquid intercooler, 66 DBB turbo, FAST and 83# injectors.
Yeah its pissing me off too.
Gasket pushed out on cylinders 1 and 2,
This is what I'm getting at. I never had knock with alky either. Nor have countless others. After the fourth gasket change,I gave up on alky. The last time I blew the gaskets with alky I heard that distinct popping sound as soon as the alcohol was turned on at 5 lbs. of boost. With the blown gaskets still on the motor,I turned the alcohol off,added some zylene and didn't hear any popping until 20 lbs. of boost.It was the alcohol. My first guess is that it was creating great amounts of pressure. After quitting alcohol,I didn't blow head gaskets again until the Walbro decided to give out. Water in oil. I find it very interesting that water goes into oil when you blow a gasket without alky and gets pushed out of the radiator when you blow a gasket with alky. I think this shows that the two different fuels do very different things in the combustion chamber.I guess I could try straight race gas and no alky when spring rolls around to take it out of the equation.
