Here's the story on why I'm at this point... bought the bigger turbo, and changed the fuel pump warlborough 355... I knew the motor needed more fuel with the bigger turbo... mechanic puts the turbo on doesn't change the oil does not wait for bigger injectors to arrive... engine gets knock... so I decided ima do majority of work myself since I have nothing but time on my hands for once... I'm going with eagle rods, je pistons standard size bore, arp head studs arp main studs, high volume oil pump. Obviously the block needs a good inspection. I wanted to keep the heads stock for now though . However everyone's input is appreciated. I know obviously to upgrade the heads or port and polish these would be wise for power gain and obviously since the motor is gonna be removed from the car in about 3 hours
