boostmaster
- Aug 20, 2001
Hey guys I made a major screw up. I ordered a set of custom pistons without verifying the actual rod length and ended up with a piston that's 0.147" out of the hole. I thought I had 6.350" rods when I actually had 6.500" rods. It was my screw up so I can't send them back. Can I simply stack some head gaskets to make up the difference and if so how will this affect the intake alignment on the block? Also the block has been decked .006". Deck height is 9.529", this is with a 3.625 stroke.
