Help no spark
RandyWallace1
first I changed plugs and wires and still running rough, decided to change oil and filter and coil pack. Car fired right up and then died, won't start and no spark. Put back old coil pack stlll no spark.
I would start looking at wiring diagrams, also check fusible links at the starter, ground for cci
I think the module is the only thing that uses the c3i fuse.
Throw a new fuse in. Disconnect the module plug and see if it still blows.
check the wire's inside the coil's makes sure there not pinching with the case when you put it togther with the module or other .wires.
Disconnect wiring from module (1/4" nut driver).....replace fuse. If fuse doesnt blow...its the module. If it blows....its wiring
