3.8L V-8 eater
- Jul 22, 2006
Where is your gage hooked up to? If it's in the tee by the turbo oil feed line then I would think you should have pressure on the gage. Do you have pressure coming out of the turbo feed or is it just trickling out? Maybe the gage is bad or you are missing a oil plug and it's just dumping out of the galley into the block.
Stock front cover or replacement?
I am running out of ideas other than open the engine up for inspection.![]()
Yes, the guage is hooked up at the tee by the turbo oil feed line. This whole thing has me sick lots of time and money invested in this whole deal :frown:
As far as pressure coming from the feed line. There is a good amount of oil coming from the line definetly not trickling out, but isn't coming out with any pressure just some volume. i would equate it too pouring liquid through a tube and watching it come out as a free fall but not any pressure.
Going to call the builder this morning and see if he recalls putting in the oil valley plugs behind the timing chain as suggested by Otto.
Nick, I will double check your idea as well.
Thanks guy's
