turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
Help
Just got this thing back in after a rebuild (myself). Just put it in yesterday and is not working correctly.
I have 3 problems
1. When putting the car in gear (D or OD) from N or P it takes longer than normal to go in gear about 2 seconds. Reverse is normal time.
2. When appyling aound 1/4 throttle or more the car revs way to high and will not shift to 2nd and will go to the rev limit. Light throttle it shifts. If you lift off the gas as its approaching the rev limit it will shift. All other gears shift fine at all throttle angles.
3. No manual low/1st gear engine braking under 25mph or less it will not downshift to first manually. The car will downshift to first when stopped with gear selector in D or OD and take off in 1st like normal. And car will hold first gear if manually selected from a stop.
2-3, 3-4, manual 4-3, man 3-2, l/u all works fine.
TV adjust has minimal affect and every now and then it will hit 2nd at 1/4 throttle. Fluid still looks/smells fine, cooler was cleaned with trans cooler flush (only has aux) trans did not have metal when tore down just 100k and the 2-3 was slip/flaring (direct clutches were on the way out).
It has a Art Carr Hih Tech VB kit in it
The trans was built with PTS Extreme parts and a raybestos banner kit:
Psi Reg system
Billet froward drum and center support
Billet anchor pin
Wide band
Adjust servo pin with stock servo modded per Bruce
Roller low reverse center support
Alto red directs frictions
Alto red OD frictions
Raybestos clutches everywhere else
Hardned pump rings
All seals replaced
The small sprag /1 way roller was replaced (dont remember the area it was in)
I have 3 problems
Psi Reg system
Billet anchor pin
Wide band
Hardned pump rings
All seals replaced
