I'm setting up my TPS and IAC in my 87 GN and a problem that I am running into is that the TPS once set at idle voltage of 0.40 volts cannot achieve the 4.5 volts at WOT and only getting 3.78 volts. I've checked and confirmed that I'm getting WOT at the throttle body blade and it seems like the TPS sensor needs another 1/8" of travel or so to get it to the 4.5 volts.
The TPS has a smooth voltage increase but again I'm not getting the 4.5 volts with the throttle lever travel any ideas...is the TPS faulty?
Regards,
Tommy
Regards,
Tommy
