dfirefighter
- Mar 29, 2007
I have been having trouble tuning. here are some of my numbers with a auto xray scan tool.
In closed loop:
- no trouble codes
-IAC= 13 steps
-coolant temp.= 193.0 deg.
-Eng. load= 29-33
-Eng. RPM= 775 average
-TPS= .43, 4.66WOT
-Integrator= 123-134
-o2 sensor= 237-858 mvolts
-MAF= 4 gr/sec. , 228WOT
-Block learn= 160 (having trouble with this)
-o2 cross counts= 13-250
-manifold air temp= 113.0 deg.
-Batt. voltage= 11.4-11.9
-proportional o2 step= rich/lean
-rich/lean flag= rich/lean
the problems im having are, sometimes when i put car in drive it will stall. starts right back up. reset tps/iac, and not sure if it is cured but now sometime car still bogs down when put in drive. sometimes stays idling and sometimes stalls.
other problem is block learn. I have new ac delco pcv, pcv gormet, egr solenoid, egr is fairly new, MAF is a new remanufactured ac delco from nos4gn Buick Grand National Parts Home Page, vac lines seem ok. not sure the best way to check for leaks thoroughly.
im sure i did more but my brain is very tired from this car. any help would be awesome!
In closed loop:
- no trouble codes
-IAC= 13 steps
-Eng. load= 29-33
-TPS= .43, 4.66WOT
