Ok, once the car/transmission is warmed up, when I step on the gas and let go, I get a very annoying CRACK-CRACK-CRACKling noise when I let off the gas after boosting. Also, I get this crackling noise directly after I rev up the motor after putting the tranny in neutral while I am cruising. I looked under the car and everything looks tight/normal. I also removed the converter cover and all the bolts are there and tight. The noise appears to be coming from directly underneath the car. It makes different amounts of this crackling noise at different times..
I also noticed that when I put the car into Drive, it shifts into drive abruptly sometimes. (Also, the vice versa--if I go from Drive to reverse or vice versa, it shifts into that gear rather abrubtly, but only sometimes)..
It appears to be something with the tranny, although it shifts perfectly. is it possible that something behind the pan is loose/disconnected??
How do you drain the tranny oil so I can remove the pan to see whats going on?? (theres no oil drain plug surprisingly!) This has been driving me nuts for the past few months..
