- May 24, 2001
John...looks like something is leaking..now to find out WHERE before you go ripping things apart....use ye ole' trusty carb cleaner...spray it around all the vac lines, and at the connections for the MAF to Throttle body pipe...also use it on that adapter at the very back of the intake.
Listen carefully for idle changes..I would hate for you to pull the turbo off the car to get to the turbo-intake adapter to only find out that it wasn't the problem!
