- May 29, 2001
John, go ahead and clear the computer, do this by disconnecting the negative terminal of the battery for a few seconds, then re-connect it.
Then CHECK THE INTAKE TUBE to see if it's still connected to the MAF sensor and the throttle body! THIS IS IMPORTANT! If it's disconnected, re-connect it before starting it!
Go ahead and start it, and let it idle about 3 or 4 minutes. Keep an eye on the "service engine" light to see if it comes on again! If it DOES come on, make note if it goes out or not, and if it comes on AGAIN before you shut it down.
let us know what happens, and we'll go from there!
