spross86
- Jan 6, 2015
SignUp Now!thanks Eric I will tonight. also I did not post this last night but I unplugged the TBS and it runs with out it a lot better I may have found the problemMake 2 datalogs.
One with engine off/key on, pressing the gas pedal a couple times. Only needs to be 5-10 seconds.
Second log, record it with the engine running at about the time that it stalls.
Eric
1st one key on pedal to floor 5 times. 2nd motor till it diesMake 2 datalogs.
Eric
Eric where you able to look at the data?Make 2 datalogs.
Eric
see if this works I cant review them in logger or on PCNo, it looks like you attached some videos, not datalogs. If you could attach the datalog files, that would be great.
Do they have any numbers/letters on them? Throw em into google and see what throws up.can you guys look at the injectors in my car I went to the Orlando club meet Saturday night and everyone is
telling me that 36lbs injectors are blue and mine do not have any blue anywhere? is there something I am missing?
The Lucas blue tops are 36.5 but there is a few other 36 lb injectors out there. I can't open the file to see them.
Accel injectors for mustang?Do they have any numbers/letters on them? Throw em into google and see what throws up.
I have a fuel pressure gage hooked up to it and it stays steady at 38lbs even till it stalls. I installed the new ECM with the TT chip last night and same issueI don't think I see anything in the tune that's causing it to stall. Those logs were rich because you are running a stock chip with bigger injectors, but that normally won't cause a stall since those are only 36's.
I'm wondering if something is failing, like fuel pressure dropping out, or ignition module getting hot, etc.
All brand new first thing I did!How old are your vacuum lines. Might be time to replace em.
