Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
SignUp Now!1571 @ 800 rpm was this after a WOT blast on the highway? or is this sitting and idling with the a/c for a bit.
If you just idling and it's that high i would check to see if that EGT gauge/coupler is working correct.
Also like so other guys have stated your a little to rich on the alky. the stoich on methanol is 6:1 compared to 14.7 on gas. What i have noticed is when using alky you would s try and target your AF about .5 richer than on gas as a good starting point. When i used to run my car on alky @ 20 psi of boost my AF was 11.8 with no issues.
A thread I recall reading on AFR with 93/alky :wink:
http://www.turbobuick.com/forums/al...w-does-methanol-affect-wideband-readings.html
Do your headers glow during normal cruise? Mine have a very low glow from driving around if you look at them at night with no light around but you have to really look for it. If your EGT guage is correct, they should be bright orange when you pop the hood at night.
yeah i have read that too.
some say about a point lower and some say tune it as it was gasoline. I myself found to make it about .5 richers and it seems to be ok. course my car on straight 93 octane when i had the factory ecm would want the 02's to be in the 800's to the 830's for the best et/mph @ the track.
well i have been working on E Singer on his hot-air and i think we have his target AF set for 10.9-11.1 on the alky @ 25lbs of boost. i can't remember but he has made 303hp on a mustang dyno. stock heads and cam.
i have been around the HA for a little bit and understand their needs.
Jerryl I know when my probe finally cooked last year on my EGT meter it read super high. Might want to get a new probe for it. I have the address here somewhere I think. They are only supposed to be submitted to like 1500 degrees at a time and we do tend to go higher then that. I bought an extra one. A friend told me where to purchase it from and once we installed the new probe better readings.
Right now with everything tight from freshened motor I noticed my EGT readings were 900-1100 this weekend getting break in miles in. This with temps in the low 80's.
Hope you post what you find out.
Jamie
What's the NB Sensor by the way?
I have nothing to contribute except to say that I installed the Powerlogger in a friend's 87 GN and wow. It makes me feel like I've been wasting my time all these years tuning blindly.
