T- Type Tim
Vice Chairman
- Jul 8, 2001
425 bux from summit with $ 19 handling charge shipped
good price ?Any better deals out there?
SignUp Now!I have a 2nd set of wheels, and I run a 295/55 on those. They are 15 x 9 with 4.5 BS and the clearance between the tire and frame is very close, like 3/8 - 7/16 ish. An 8 inch rim would pull 'em right into the frame.
I've seen quite a few of our cars at shows rocking the 275/50. For looks, I kinda like the shorter profile. It's sort of a personal taste thing really, until you get going fast at the track, then it becomes an RPM vs trap speed issue.
No sidewall height issues with the 275/60. So far I love the Nittos. They hook great at the track and the tread seems to be lasting longer than the Mickey's. I found the Mickey's hook a bit better on the street compared to the Nittos, but the Nittos last longer and are better in the rain by far.
1.58 and that was launching it easy. I run 18 psi in them.What was your best 60 with the Nittos and what pressure do you run them at on the track?
I think all safety equipment is based on how fast the car is. They won't know if the Turbo is after market. If you're faster than 13.99 you need a helmet, and faster than 11.50 you need a roll cage.No problem! Going to try and make it out there next Friday if the tires show up.
Since you guys hit the track a lot...... do you guys have a recommendation for a fire jacket? I understand that use of an aftermarket turbo requires a jacket?
Again I appreciate the help!
Those are the cragar equivalent of weld pro stars with 4.5" of backspacing.... Not sure they make themwhat type of rims are those and backspacing
I always drive around it, then back in. I do a pretty decent burnout. Had the air pressure around 16-18 psi. If you do about 5-6 passes you can definitely kill these tires in one track day.Do you guys roll thru the waterbox at the drag strip or go around it with these tires?
