Vendor Defendor
Out the window
- Nov 25, 2002
A while ago someone broke into my car and since then my horn does not work. It could be a fuse, but I looked at the fuse box diagram and didn't see any fuses for the horn... so does anyone know off hand what fuse is for the horn?
Then, a related problem (I believe) is after this break-in I think the theifs ****ed around under the dash because now there is this 'clicking' coming from under the steering column, at least thats where I think I have narrowed the field down too. The car makes the noise in one of two senario's, I guess it depends on what kind of mood the car is in; it either makes it when the horn button is pressed or when the wheel is turned. I believe that the noise is something electrcial because it is only made when the battery is hooked up, or so it seems.
Any Ideas?
Any Ideas?
