hoses blowing off under boost
soundguy
anyone else had issues with vacuum hoses on fuel regulator and egr blowing off at high boost? adjusted boost limiter farther than I thout this weekend and when starting on highway (was empty at time, late at night) I hit 24 psi, higher than I shoulda considering 7th inj not in yet. I found 3 hoses blew off under hood, replaced and used tie wraps to tighten em down, but concerned about it happening again.
if the hoses are old, replace them all with new hose and use either the worm and roller to spring loaded hose clamps. if the hoses are in good condition just get a set of clamps.
super glue + tie wraps
be especially careful with the regulator line.....many bad things can happen if that one comes off under boost
