Hot Air Head gaskets, which ones
ronbuick
What are all you folks using for head gaskets for the hot air motor, and what choices do we have.
thanks
Ron
stock is what im using. there getting hard to find.
I have been told by a couple of parts houses that the N/A and the turbo motor take the
same head gasket, is this true??
Ron
no
No they are different i think they have different compressed thickness and different compositions
I use the felpro 1000 and have had good luck but others will chime in
84 block 87 setup ++++
Felpro 1000
20lb boost ++++
Long as you have enough fuel they will do fine
headgaskets
84 block/87 set up
RJC headgaskets-20lbs of boost with alcohol
ARP studs
