how big with alchy/propane? 50's msd
BOOSTEDGNs
My combo is gn1 alum heads rockers
art car trans If I remember 35-3600 stall have to check my receipts
hemco
alchy 2 stage/propane
50's msd ,new racetronix injector harness w/ hotwire
255 pump w/ hotwire
translator plus
yada yada yada on and on
but question is how big can I get away with on the 50's with alchy/propane
Im looking to walk on razors edge car will see little to no track time mostly grocery getter and whatnot
Alan
Id just go with a te45a and a .63 housing if your not looking for every single horsepower- Since you will be doing street duty more than track duty, a te45a will spool faster than a 70 with that convertor-
If you decided to go larger, then you might want to step up the convertor some
Id get a meth kit and not a propain kit, just my opinion
BW
With your combo I would definitely go bigger than a 62. Hell, I had run a 62 with a stock motor and converter a few years back. Take a look at CPT66, a GT67, or something else in that size range.
TE45a is a t-66 turbo that is stuffed in the small housing to appear just like your pte51- pte54, the TE45a flows 1050cfm.
You also can get TE45a as the largest TA series housing and still have a stock appearing turbo.
The TE45a loves boost!
BW
thanks quick6 and benstr
45 sounds like it might work for me Im gonna do more research Im probably most likely gonna float around with my spare stocker and keep my fingers crossed for something used Im scraping it presently until dec and am holding on to the dollas for dear life
returned to school for a career change and working out the bugs in that category
again thanks and if you have more suggestions please send em Im gonna look up the 66/67 and 45
whats this Ball Bearing turbo I read about you guys happen to have the scoop are they more reliable for daily drivers?
thanks
Alan :D
