How do I install a MBC???
Quigs
Trained monkey
I just made a MBC but I'm not quite sure what vac. lines to hook it up to. :confused:
Thanks Phil
If it is a spring and check ball set up, spring end goes to the wastegate port and ball end goes to nipple on compressor housing.
HTH
Thank you
I first tried also connectting the wastegate selonoid with the rest of it and that didn't bleed of any boost. If I hit WTO it would have pulled over 20psi for sure. But now its good
Yea, my wastegate solenoid just holds the harness connector in place now :biggrin:
