How fast can you go with 36#-ers?
GN84Turbo
Where'd all my money go?
Just curious on how fast people have gone with 36-37 lb injectors.
I've gone high 11's with them in my 86 GN. I've gone high 13's with them on my HA 84 Riviera T-Type with the stock turbo and motor. Its a 3900 pound car so you should be able to do somewhere in between with out any problems.
Cool, perfect. Just needed to know how far I could get before going to 42.5#ers. Thanks! High 11s is my goal...for now. :biggrin:
high 11's in what? and if i where you my next upgrade wouldnt be 42.5 it would be the high z 60's.
Full Weight Gn 11.69 Stock Ic And Blues
are we talking about how fast have people gone in a hotair car or intercooled car with 36's? big difference between the 2
um..my 84 GN, hence my website. :rolleyes: And why would i go with 60#ers?
id have to get a new ECM; im not going to switch off of the stock ECM. The biggest id go is 50#, which is supposedly the highest you can go on the stock ECM. Thats plenty of fuel to go 10s, and im not even sure i want the car to go that fast.
I wanted to know the potential of 36# injectors, regardless of an IC or not. I now have an IC, but still hot-air motor and turbo setup. Check the site if you want to know what im working with.
You wont have to switch ecms or do the driver mod to run the 60's. fullthrottlespeed.com has high z 60lb injectors that work with the stock ecm no driver mods needed. Also why would you go to the 60's. Why not there more injector then you will ever need thus you will never have to upgrade. i have gone from stock injectors to 40's to 55's. i wish the high z 60's where around back when i started it would have saved me alot of money. Also with the chip burners we have today they can make the 60's work on anything so to me the 60's are a no brainer
