how fast on stock ecm,maf
tta1240
CAMEL TOE
i am trying to keep my car as simple and ameture tuning freindly as possible.i got rid of my trans pro.and was wondering how fast a stock pcm,maf,tt chip have gone.i have a SD chip,and a power logger but may put the maf sensor on and use a TT 5.7 scan master till i learn more about tuning.i was wonder if anyone beside Grumpy have dipped into the 9s with stock stuff.
If you can dip below 10.50 with a stock MAF with a screen in it youre doing pretty damn good.
Did you mean stock ecm while using any MAF or a stock MAF? Stock ecm cars are well into the 9's but like Bison stated, not with a stock MAF.
For a guy that can't make a lawn mower run and is twice as dumb as he is ugly I'd say chances are slim to none but for you 9's shouldn't be a problem. :D
use what you have and see how fast it will take you... you need to learn your car and give it what it wants.
ya i do need to learn my car more for sure.when i took out my hacked up harness and replaced it i did not reinstall the trans pro,i thought a translator 3.5 maf and a tt chip would be easier to use.Dr Boost where you been i have not seen you post in awhile.
i plan on going with a translator and a 3.5 maf,then to my SD chip after awhile
i ran 10's with the stock maf,stock ecm,5.6 tt chip,pump gas alky,no powerlogger.
I used to tune a car that ran 10.18 on stock ECM/MAF
Stock block/crank and rods too.
