SignUp Now!Has anyone tried the ebay stainless headers?I'm sure they are from China but for street applications they should be ok unless they don't fit.Let me know.Howard.
And if you can't afford the K1 rods, you may want to consider SCAT h-beams thru Ebay for around $407.00 a set.
I have made over 50 passes on my new DLS built 109 with factory rods. Just for the record at over 750 hp. It can be done, it may be better with after market rods though? Good Luck.
Can u say HIJACK
I've seen LOTS of bent rods, but have never seen one break that wasn't caused by crank/piston failure. If you plan on making more than 600hp. then be safe and use K1 rods. The factory rods will live at 700 hp. IF, and only IF, there is NO detonation. Period.
