SignUp Now!fitz3820 said:New GN bumper sticker: "Weak Springs Save Cams"![]()
It is tough to know for sure because you dont have a broken or mangled part to see. It comes down to experience and shall we say aquired knowledge over time. Most people dont have a spring tester so you really dont know what you have for pressure like bison said. Find yourself some" spintron valve spring" videos on youtube to watch.... there interesting to seeAfter reading those threads, the question remains left the table(specifically the second thread). There's some helpful info in there, but i hate it when a thread is never "solved." I normally try and close out threads that I start with coming back saying "its fixed" or "still having issues" or something. Hell, after reading the symptoms, Im almost sure that I need some valve springs.![]()
forcefed3.8's said:A friend of mine had a set of 941's that were over 10years old, and had 20,000 miles on them. When doing head gaskets, I pulled them to test them, 100 closed, 300 open. He was seeing valve float. After swapping springs, the car runs the same at 23psi than it did previously on 27psi.
fastblackracing said:It is tough to know for sure because you dont have a broken or mangled part to see. It comes down to experience and shall we say aquired knowledge over time. Most people dont have a spring tester so you really dont know what you have for pressure like bison said. Find yourself some" spintron valve spring" videos on youtube to watch.... there interesting to see
williamsGN said:Bison, what is your take on Nick's comments on spring replacement ? I have no idea on the status of my springs. This motor was rebuilt with the best of everything.. forged pistons, arp, etc. No idea what springs, but I know i can spin 5300 at low boost. I would rather not wipe a cam on the possible advantage of new springs and from what I read, stock replacement springs won't net an advantage over the possibility of cam damage.
Check with Nick Micale who has built dozens of engines and he will explain how they are not a wear part unless you are having valve float, RPM issues, etc. They are not wear out parts like timing sets, etc.
http://www.turbobuick.com/forums/threads/timing-chain-valve-springs.367378/#post-2933762
http://www.turbobuick.com/forums/threads/when-to-replace-valve-springs.52702/#post-424479
"Turbo-T" said:Thanks. I understand valve springs gob ad with time, just it seems I've seen more asked on them with the TR crowd than some of the other boards I frequent.
I'm pretty sure I've got a valve float issue attributed to weak valve springs. The car pulls like a mofo until around 4000, then it seems power starts dropping off, around 4800 it sounds like it's popping/sputtering...sounds like a "dut-dut-dut-dut-dut-dut" when it does...like a rev limiter was installed but there is no rev limiter. You can even watch videos of me racing the car....you can see it looks like it pulling like a bat out of hell off the line but it doesn't appear to increase much more in speed. Car only picks up 17-18 mph in the last 1/8 mile of a 1/4 mile track which I know is not good/should be at least 20 mph.
I have no idea what springs are in it, much less how old they are or even if they were set up correctly. Engine was supposedly redone before I got it but I can't verify who did the build to ask. I have the cam card that goes to the cam (old Postons grind - in my sig) I've tried the usual of changing filters, coils, plugs, compression checks, fuel psi checks, unhooking waste gates to not make boost, etc.
Maybe it's time to throw the damn thing on a dyno and see where it start laying down and by how much?
