SignUp Now!Keep an eye on fuel pressureChip is 25 psi at 21/23 timing. Alky pump is new. I'm going to install the 24 lb spring combo in the wastegate and see how things pan out. I got the 60lb flowmatched injectors from Eric with the chip combo. Walbro 340 in the tank.
TA49.robertf--What turbo are you running?
Do you have a wideband air fuel ratio gauge? If not get one ASAP.TA49.
Probably wont make more than 22-24 lbs boost with ta49 and ported heads. Run all the boost.TA49.
Do you have a power logger or scanmaster? My stock long block motor made 500hp with all the normal bolt on stuff. Alky. Fmic. 6.1tt chip. 60# inj. Turbonetics 6165bb turbo.
With factory chip settings it would run 11.50 1/4 mi. I tuned it to a best of 11.17 @ 28lbs Boost. At 30lbs the car would run slower. So I feel the turbo was all in @ 28psi.
You need to be able to tune your combo to get the most out of it. I would think the ta49 is probably all in on your combo by 26-28lbs. You need to watch the afr and add fuel as you add boost 10.8-11.2 is considered safe if everything else is up to par. The way I tune alky is to start with the base settings. Add boost and fuel until I’m running max boost with safe afr. Then subtract fuel and add alky until I have replaced approximately 25% of the fuel with alky. Avoiding all KR. during the tuning.
