How much can I ask for my motor?
evil666
I have a 109 block that has between 600 and 700 miles since my total rebuild and something went wrong with the main bearings. I could sell the motor fixed but I rather sell it broken so this way the buyer could get it rebuilt by the engine builder that he wants and maybe even get a warranty. It is a 109 block with a N/A crank, billet center mains , weisco forged pistons, stock rods, arp studs for the mains and arp bolts for the connecting rods. The rings could even be reused since the new motor didn't have a lot of mileage. This short block is without the cam, timming chain cover, and double timming chain. What I want to know from you guys is how much can I ask for this motor and add at least 300$ for shipping of it.
Marco
T-Top 86 Grand Nationals (63000km) 109 block with weisco forged pistons and 2 billet center main caps, M&A aluminum heads, roller rockers, port match lower intake ,te63 a.r .82, erson 214/214 cam, razor alky injection, 94 octane, hooker cat back with dyno max ultra flow muffers, kenne bell headers, 60 lbs injectors, extender alky chip with 21/19 timing, with a gen 2 with a LS1 maf,thdp, mease 24 row IC, PTC 3200 stall 9 1/2 convertor, Ron Custom max boost brake module, MT drag radials (275/60/15) , rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, Weld Drag Lites with skinnies up front, electric exhaust, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms, Big mouth cold air with an AFE air filter
BEST E/T= Exhaust closed
60FT=1.48 (foot brake on 4 lbs of boost)
1/8= 6.65 at 100 mph
1/4= 10.83
MPH=105.2 (letting off the gas, car was running to lean, double pumper for next year)
Any opions please.
Marco
1/4= 10.83
ill give 100.00
Sure I will give you 2 arp main stud bolts for that price.
1/4= 10.83
What went wrong?
Did you not have a warranty?
It's impossible to put a price on it over the net and without knowing exactly what went wrong.
Need to list who built the motor. Balanced rotating assembly? did metal go through the motor?
I think I would take the caps,rods and pistons out and buy another crank and build you a new motor.
Very hard to put a value on someone elses property without knowing all of the specifics. Just my opinion, I am not looking to purchase.
Bryan
I'll give you a price. Motor unseen, from Canada, and at the very least needing the bottom end rebuilt... 1000...Not a dime more from someone who knows these engines. Having a NA crank in it does not help the situation either.
What went wrong
Need to list who built the motor. Balanced rotating assembly? did metal go through the motor.
Bryan
The honest truth is that this motor has been rebuilt twice in the 600 to 700 miles that I did. Both times because the main bearings wore off and I don't know whyThe machine shop and the builder are to different people. The first time it broke down the machine shop didn't want to take any responsabilty. So I rebuilt it again with the same engine builder but a different machine shop. The new machine shop couldn't find anything wrong with the motor except for telling me that it was contamination caused by an oil additif. I had a hard time believing that because the only thing I added to my oil was zddp, but went ahead and got another rebuilt. Drove a few hundred miles and the same thing happened again. Oil psi starts to drop slowly. The last time I saved the crank because I caught right away so the crank just needed a polish, and this time I think I caught it right away again but haven't had the chance to really check it. This time my friend which is my engine builder says that it happened because I used 5w30 oil instead of 20w50, but I have a hard time believing that because the first time it happened it was with 10w40 oil.
Two different machine shops in montreal and A friend of mine was the builder and yes the motor was balanced. Anyways I lost total confidence in the machine shops to getting the motor done localy. The reason I want to sell this motor is because I was thinking of maybe buying a stroker motor that weber sells that I don't have to send a core.
Marco
1/4= 10.83
