I have a 67 Firebird/LC2 hybrid that I am just beginning to get dialed in. The motor is built exactly like the motor that was in my full weight T that ran 10.50's and the Firebird is lighter at only 3175. I originally swapped a LS1 into the car and then realized everyone was swapping LSx's in everything so I swapped over to the LC2. I used the same converter I had built for the LS1. I spec'ed the converter for a 3400 stall on a 400whp LS1 with a 150 shot of nitrous so I thought it would be in the ballpark for the LC2 and thought I would give it a try before having it restalled. I took the car out tonight for the first time with high boost and I thought I was late on the shifts because it seemed I could not keep the car off of the shift lite. I then went back and checked the PL files and found that I had the shift lite set at 5300 rpms but the motor was making it 5700 by the time it shifted then only dropped back to 4900 after the shift then the shift lite was right back on. I have had a few 10 second turbo Buicks and I have always run the multi disc Vigilante converters locked so there was plenty of RPM drop with them! The car has ported irons, TE-45A(at 25 PSI) and the normal supporting mid to high 10 second parts, turbo 400 and 3.23 gears with a 28" tall drag radial. I am not opposed to having the converter reworked as I thought this might be needed(I thought it was going to be too tight!:redface but I want to make sure I am on the right track before I go thru the hassle and expense. Thanks for the help.
