How Much Trans Fluid?
turbolc2
Mongoose
Should I run an extra quart of trans fluid to reduce temps since I don't have a deep pan.I have a 10,000 GVW B&M sandwich type cooler along with the oem cooler in the rad.I will be installing a 3000 stall 9.5" Precision n/l.
I would'nt recommend much more than a pint over full, their are those out there that run a quart or more over, as for it cooling more doubt it will help. There has been much debate about this on here try a search and make a decision for youself. :D
If you put too much in the tranny, it will expand when it heats up and come out the overflow tube. This is very bad because then it wind up getting on your TIRES as well as the underside of the car & exhaust pipes.
The tires are the main concern and I think you know why.
Gary
